Maximum memory Pro-E can use
swalton44
Petroleum
GB
We have recently accuired some new machines that have slots for up to 8 gig of memory. The computer guy tells me that windows can only handle 2 gig. I say this as we are struggling with large assemblies. I find it hard to believe that we are limited to 2 gig of memory. Does anyone now if it possible to utilise more memory, the machines are hp workstation xw8000. Or if not what do people run Pro-e on to handle large assemblies?
The memory limitation is handled by the operating system and not by PRO/E. But 2 GIG of RAM is good enough for PRO/ENGINEER.
-Hora.
Have you considered running under a UNIX platform?
Take care & have fun!
Kevin
"Hell, there are no rules here -- we're trying to accomplish something." - Thomas A. Edison
Cheers guys, I don't think we can change to unix. It is more a case of working Pr0-e more efficiently.
"Trying is the first step on the road to failure"
Homer Simpson
No matter how efficient something is, at some point things get too large.
The specifics of 2 GB--2 GB is the maximum number allowable in a 32-bit operating system. So just going to UNIX won't cut it--it more specifically has to be a 64-bit operating system.
Note however that I've heard of some way to "trick" Windows into handling up to 3 GB. I've not done it myself, but two people I know of have. You may want to check with Microsoft's website on this.
Brad
The 2 Gig limit is (I believe) the limit on a single file. 2^32 = 4 Gig, the max you can address with a 32 bit system. For really big files you do need a 64 bit operating system and processor. However, I think you should really explore all the things Pro/E gives you for reducing memory requirements when dealing with large assemblies. I'm no expert on this as but there are many ways to limit what you have in memory or displayed to speed things up.
everyone here given a very good guidelines about the memory space.but as you asked to handle the large assemblies you can use simplified reps and create as many as reps you want to work.
reg,
prakash
