Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
What if the datum B hole measures on the LMC side, dia. 10.6?B(MMB) is called datum feature shift and is NOT a bonus.
Only the circled M after Ø0.2 is called "bonus" (additional tolerance) and not the circled M after B (which again is datum feature shift)
Datum feature shift is offering additional datum feature mobility (giving back some datum feature mobility)
Do not add the datum feature shift to the "bonus" tolerance because that would be wrong (very wrong).....
ok thanks. I will conclude that adding (M) on datum B does not change anything. B (M) = B.The amount the datum feature can move rarely has a good calculation for the true-position shift. There are some cases that make it appear that way, but that is misleading.
At it's heart, true position is defined relative to the ideal datums; datum shift allows the part to move relative to the datum features, not to allow the holes to move relative to the true position of the holes. The true position of the holes remains fixed. The deviation from that true position is only due to the tolerance in the Feature Control Frame.
There is no sense in adding them and they do not affect each other.
Assuming dimensions and tolerances are assigned but those should not affect anythingNo.
First off because, in this case, C is a flat surface and has no size and has no maximum material condition.
Second because (M) indicates the datum feature can wander around it's own true position independently from the amount the feature which "bonus tolerance" applies to.
Which gets back to the first part - the flat surface, in this case, is not allowed to wander anywhere - it is to be placed in contact with a real or software generated mating planar surface.
I'll be nitpicky -- that's not quite true. For a feature being toleranced with position at MMC (the four holes), that would be true. But a datum is always a theoretical plane, axis, point, or combo of those. With MMB, it just means that the theoretical axis is one that's derived from the feature as if it were at its MMB.Technically the standard says preference is given to interpreting that as applying to the surface of the hole. That interpretation considers both the amount of material and any related tolerances of location or orientation.
In your drawing, they won't affect anything because your datum is still just a plane taken from the right side of the part. If your datum feature were tagged with the span of 42 +/- 0.5 then the datum would be greatly affected: it would be a plane derived from the center of that span.Assuming dimensions and tolerances are assigned but those should not affect anything
Correct?
Thank you
