Can anyone suggest a maximum recommended welding heat input, in terms of kiloJoules per inch (or per cm), for aluminum in 5000 and 6000 series alloys such that we will minimize changes in chemistry or increased susceptibility to cracking or potential for stress corrosion.
Purpose is to back into welding variables (volts,amps, travel speed) from the recommended max heat input value and then proceed into a procedure qualification. Typical application will be for "as-welded" condition.
Thanks for any guidance offered.
