MAX Dimensions 3
Matthew2323
29
Would a length dimension ever be modified by MAX? Because zero (0) is less than the MAX would that be acceptable?
I could understand a corner with a R.020 MAX meaning that a near-sharp corner is just as acceptable as R.020.
So in what other applications would the MAX modifier be used?
Thanks,
Matthew
I have seen MAX used for tap drill depths with the thread length given as MIN.
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
Thicknesses of coatings perhaps? For example, if an item was getting powder-coated there might be a MAX that it can grow by and still function in the space intended.
Any place where you would be dimensioning a gap in an assembly as well. For example, if you had some handrails that form a "T" shape. If the handrails are touching, that's fine, but I don't want the gap to be big enough that somebody can get through.
In discussing how many pairs of leopard print shoes a person needs.
In accounting and finances (I will pay $4 MAX.).
-- MechEng2005
Any situation where you have some kind of burr, trim, flash, machining 'mark' or these sorts of things 'MAX' often has application.
In essence, a situation where you'd prefer '0' but because of real world manufacturing constraints etc you need some permissible maximum distance/size.
