When designing Fixed Tube sheet Exchangers having Shell Expansion Joint, as per ASME Sec VIII Div 1 by PV Elite, it is observed that MAWP on Shell Side and Tube side due to Expansion joint effect (especially its annular flat portion)is much lower than Design pressure. PV Elite appear to give a mild warning not firm like if lower by other components.
1. Why PV Elite does not give firm warning.
2. Does code require to calculate MAWP for Expansion joints also.
3. Meeting this condition appears difficult due to thinness of the Expansion joint / Bellows.
4. Is it necessary to comply with MAWP to be always higher than Design pressure even with Expansion joint effect.
