MathCAD Prime Express 4.0
Worldtraveller
Aerospace
I have still been using MathCAD 12 (I think, very old version that works just fine).
So far my initial impression is unfavorable, but I don't know how much of that is due to Express' limitations. Also, this is my first time trying Prime, so some of these issues may have been around since they changed to the MathCAD prime format.
1. Is there a way to change the interface to 'Classic MathCAD' (auto detect text or equations, use the '.' for subscripts, etc.). If I have to learn all new keystroke shortcuts, I may as well use MS equation editor and do the calculations by hand.
I'd like to keep this thread open for future questions/discussion if possible.
MP Express IS essentially a WYSIWYG calculator. My recollection is that M12 was a particularly bad version of MC, as that was the start of the re-write of the code of MC, and it really took until M15 to fix everything functionally to the level of M11.
I'm personally still using M15, and it's unclear whether I'll ever switch over.
There was a controls template that one could hack to change things like units and shortcuts in the older versions of MC, but I don't know if the same applies to MP.
TTFN (ta ta for now)
I'm going from recollection, my version might be quite a bit older even than M12.:)
Point is, it seems to work great, even in Win10, and I'm not seeing, so far, a reason to go with the new version, but I don't think I can get an old version at my new job. :/
It's not terrible, but if I have to relearn everything, it's really going to slow me down for a while.
I am still waiting for Mcad Prime users to say it is safe to upgrade to Mathcad Prime.
I stopped upgrading at MC13. MC14's symbolic solver wasn't as good as MC13's.
I think PTC owned MC when the upgrade to MC14 was made. They broke the solver.
@IRStuff, does MC15 work with Windows 10?
I must run my MC13 on a WinXP virtual machine.
I still use MC13 a lot. I have a lot of files ( history ) using MC. I have about 800-1000 MC files. I am slowly converting the most important files over to Python if they are math intensive. The symbolic problems I have converted to Mathematica. Mathematica was only able to solve about 1/3 of the symbolic problems that Mathcad couldn't.
I have downloaded the trial MCP and tried it. I am not impressed with putting lipstick on a pig. I bet that PTC doesn't have any engineers/programmers that really understand MC so that they could improve MC's internals.
MC has a few severe faults. wxMaxima and Mathematica will allow symbols to represent formulas. There is are operators that allow separating a symbols left hand side of the equals from the right hand side. Basically, symbols that represent formulas can be manipulated. There isn't as much cutting and pasting in wxMaxima and Mathematica as there is using Mathcad.
Mathcad will always display a-b as -b+a. I hate that.
Mathcad does not optimize recursively. Many times I must copy a sub-expression and optimize it separately then substitute it for the original sub expression.
The Mathcad minerr routine is poorly documented and doesn't work very well. I can provide the same initial guess and get different answers every time I hit control F9.
I have been using Mathcad since version 3. There are many time people post MC files that I can't open so I can't help. I probably have a good example.
MC is good but has never been ready for prime time.
Peter Nachtwey
Delta Computer Systems
Well, bear in mind that M15 is nearly 7 years old, and it is indeed a wonder that it actually does run in Win10, although, I'm not a power user like Peter, so I can't attest to EVERYTHING working.
For whatever reason, Mathsoft, and the PTC, collectively decided to make the Prime file format incompatible with the original program; not unlike block chain splitting, I guess. After the debacle of the code rewrite for Mathcad, I think PTC decided to take the slooooooow approach to re-writes, to avoid the previous catastrophic releases. I think that MP5 supposedly was planned to be the equivalent of M15 in functionality, but MP5 was supposed to beta-test near the end of last year, and release this year. I don't know if I'm out of that loop, or it's just that nothing's happened. A likely possibility is that the slow-roll of MPx caused a lot of users to bail, and there's insufficient revenue to justify making the next release.
Since PTC took it over, the work stopped and customer service decreased...
Dik
They cranked out at least 3 versions of MP after the acquisition on their own, over a span of 7 years, so not exactly a work stoppage. Certainly, they've gone into glacial progress mode in the last 3 years, so there's that. I think most of the original Mathsoft personnel have left the company, and there may no longer be a highly-placed product advocate at PTC anymore, such as Razdow.
None of the new versions have been anything to write home about... the company was far more dynamic before PTC.
Dik
I don't have any issues getting it (MCP 4.0) to run on Win10. I just hate that they completely changed the keyboard interface and none of the 'normal' mathcad keys work to write equations. I really only use MathCAD for basic algebraic stuff and rarely need anything more advanced than a simple 2D graph.
That said, since the main reason for using MathCAD is to make the equations look right when I paste them into my reports (and it's nice that the calculations are there), there's not much point in using even the free version, much less getting my company to purchase another license.
Time to start learning MS Equation Editor. :/
Thanks for the input.
Last I heard, MP4 still comes with MC15, which was the last version prior to the interface change. As mentioned earlier, I'm still using MC15, which was, and is, perfectly adequate for anything I do.
I am under the impression that soon enough MC15 is going to no longer be supported, and therefore I might as well start converting my files over to Prime as soon as possible. I suppose there is a converter but I have not used it as of yet.
I am not a power user of any Mathcad with about 100 Mathcad files and have only recently switched over to Prime 4.0. My first impressions are that things like the page ruler and print settings are very minimal, but for the most part if you do straightforward code formulas (ASME BPVC, AISC 360, etc.) the Prime version will likely be sufficient for most of your needs. I have yet to use it for evaluating equations for specific variables, as I had used MC15 to do for some flat plates in a few Timoshenko books, so I'm not sure how it will work just yet.
This sort of reminds me of when Ansys rolled out their Workbench front end, which looked "pretty" but was limited compared with what APDL could do, or when Solidworks came out with DesignModeler which was limited compared with what CosmosM could do. I may be off base here with my analogy, but after using Prime 4.0 for a few hours that's the feeling I get.
mathcad prime can open mathcad 15 files directly. it converts it to prime format, and you may lose some functionality. I have not had any issues, even with my more complicated sheet, with conversions.
My recollection is that it was a separate and one-way process. MP essentially uses MC15 to open the file and then transfer the contents to MP, so not exactly a transparent live file conversion.
I'm running Mathcad Prime 2.0, and I can confirm that it shipped with a separate utility for converting MC15 files to Mathcad Prime format - but they may have integrated that function into later iterations of Prime.
In my case, almost none of my MC15 worksheets translated cleanly - but again, they may have expanded the library of supported translated functions in later versions. I can't recall whether my problems were because of the functions I was using not being supported (I do use quite a lot of Mathcad curve-fitting and surface-fitting functions, for example), or if my syntax was unusual, but I am not enough of a Mathcad guru to think I would be doing anything particularly elaborate.
In the end, I gave up trying to translate my old worksheets across to Mathcad Prime, but I generally use Prime for "quick and dirty" simple calculations.
If we're collecting Mathcad stories, here's mine...
I have tried the free Mathcad prime from PTC and I find it too limited even for many rudimentary tasks (eg. vectors).
I have a copy of Mathcad 13 that still works and I expect I will continue using it until my OS stops accepting 32-bit programs. Since this is a program I have personally bought, using it at work causes some issues. At one workplace, they were willing to buy a license of Mathcad for me but the approval process took almost a year and then they installed it on somebody else's machine instead of mine. So until I left that place, I would occasionally use my personal copy of MC for calculations. Where I work now, the computers are "locked down" and without administrator privilege, I can't even install MC13 on my work PC. But I can get SMath Studio to work, it is sufficient for my more typical needs, and it doesn't need to be licensed when used for work, because it's freeware. I find the file conversion process a bit buggy, and some graphs don't come in at all. I may commit to using more of SMath long-term, which means that won't be concerned with backward compatibility with the XMCD format. I have already made a donation to the developer.
STF
I use MathCAD 2000 Pro... and it seems to function OK. More recently, I'm using SMath more and more...
Dik
Thanks for the tip on SMath. I'm going to send the link to the IT guy and see if he has any objections to me installing it on my work machine. That seems a better option at this point than trying to get an expensive license for software that's just annoying me.
I have no problem with IT... I do nearly everything on my laptop... Our IT department is a profit centre, and, they can be more profitable if they do not supply up to date equipment. Starting at the same time, I can be working on my laptop before the logon screen shows itself on the office desktop.
Dik
