A series of very low cycle and high strain fatigue-type tests are being carried out on a carbon steel material. The testing is not typically "fatigue" as such, since the specimen will be cycled approx 20 times under total strain limits of 10% (ie 10% strain range). The only material that is available is in billet form (300mm x 50mm x 150mm - length/thickness/width) and current testing of this type has always been carried out (uniaxially) on cylindrical specimens with a gauge length to gauge diameter ratio < 1 (to avoid specimen buckling problems). Hence, I am trying to understand if using flat (dog bone) specimens would be appropriate.
Any insight appreciated.
See faq569-1083 for details on how to make best use of Eng-Tips.com
