Material B 58 Grade A ????
zigiz
Industrial
Sep 14, 2006
6
Does anyone know about this material: B 58 Grade A
It is used in a pressure vessel for a semi-elipse head whereas shell is A106B.
It's manufactured in 1970s.
B 58 is not listed among current ASTM, ASME or other specifications that I searched. A 508 is a standard for tempered steel forgings for pressure vessels. B 582 is nickel-chrome-iron-moly-copper alloy.
I am not completely sure of this, however, from a copy of the "Stahlschlussel" printed in 1992. There is reference to a B 58 that cross-references HASTELLOY alloy G, DIN 2.4618.
Mark Hutton
The Haynes International web site shows HASTELLOY G-30 to be covered by B 582 and the additional specifications as follows:
ASME/ASTM SB 366/B 366 Fittings
ASME/ASTM SB 581/B 581 Bar
ASME/ASTM SB 582/B 582 Sheet, Plate and Strip
ASME/ASTM SB 619/B 619 Welded Pipe
ASME/ASTM SB 622/B 622 Seamless Pipe and Tubing
ASME/ASTM SB 626/B 626 Welded Tube
ASTM B 462 Pipe Flanges, Forged Fittings
ASTM B 472 Billets and Bars for Reforging
ASME Section III, Class 2 Nuclear - All Forms
ASME Section III, Class 3 Nuclear - All Forms
ASME Section VIII, Division 1 All Forms
ASME B16.5 Pipe Flanges and Flanged Fittings
ASME B16.34 Valves-Flanged, Threaded, and
Welding Ends
ASME SFA 5.14 (ERNiCrMo-11) Covered Welding Electrodes
ASME SFA 5.11 (ENiCrMo-11) Bare Welding Rods
AWS A5.14 (ERNiCrMo-11) Bare Welding Rods
AWS A5.11 (ENiCrMo-11) Covered Welding Electrodes
DIN No. 2.4603 All Forms
DIN NiCr30FeMo All Forms
NACE MR-01-75 Metallic Materials for Oil Field Equipment
