bgsmith
- Dec 12, 2007
- 25
I am having trouble in the design of a cantilevered masonry column system. These systems seem to be pretty typical for support of entry canopies or even larger canopy systems (I am picturing bank drive throughs). The basic system is a light roof deck (metal deck or plywood) with light framing (wood i-joists, cold formed studs or light channels). This type of system probably does not provide enough resistance to allow for a pinned column design so a canitlevered masonry column is assumed. The question is in the lateral seismic force calculations what R value do you use from the ASCE? There doesn't seem to be a value that corresponds for cantilevered masonry columns. I tried a small value (R=1.25) but the design of the footings seems unreasonable. The ASCE forces you to use the overstrength factor for footing design for cantilever column systems and this makes the overall overtuning force very large. Has anyone designed this type of system?
