We are doing some burst tests for manway pressure rating. The maximum test pressure is usually limited by leaking from gasket before reaching the desired pressure. As a result, we will get a lower rating pressure for the manway although the steel components may be able to stand much higher pressure.
Is this right? Should the gasket be included in the test? Thank you,
