We have a Client that we are building a non-stamped vessel (under 15psig and non-lethal and 1/2"-5/8" thk) to ASME Section VIII Div 1.
Client has stated all welds in material ½ in. (13 mm) and greater in thickness may be examined using the ultrasonic (UT) method given the requirements of 7.5.5 of Section VIII, Div. 2.
Per these reqs, my question is, "Is manual shearwave UT method acceptable?"
Thank you for your assessment and comments.
