you may also want to investigate the sensativity of your stream to a change in N value. How much does varying the N value affect the resultant flow velocity, depth, sediment transport, scour, flow regime etc. Also, check around and see what is usual and customary in your area.
SCS (NRCS) has a method which is widely used which considers several factors. For example:
1. Basic N value for channel in earth 0.20
2. Modification for vegetation (grass) 0.005
3. Modification for channel irregularity (avg) 0.005
4. Modification for Obstructions (minor) 0.005
5. Modification for Channel Alignment (avg) 0.002
N = N1+N2+N3+N4+N5
N = 0.037
Chow (1959) would indicate something between 0.030 to 0.050
depending on the alignment, bed and channel condition etc. You would need to quantify the following:
rocks, pools, shoals, ineffective flow areas, timber or underbrush, flow stage, channel alignment etc.
Also, if you have a high water mark and if you can correlate this water mark with a known flow in the channel, you could then back calculate the N value to verify your assumption.
Another thing to consider is that the channel has a "movable" bed. In other words, during a flood, the channel cross section may change shape. Weeds and grass may be washed away and sediment transport may deepen the channel or form sand bars. The channel may migrate laterally. Is the N value during the flood event the same as it is on a sunny day? Chuck
cgopperton@stantec.com
