Making a Non Associative Spline Associative to defining points.
uglord78
12
I am working in NX7.5.3 and I am creating studio splines by selecting the points, one at a time. I noticed that it is possible to use the old spline operator and select all the points at once and create the spline. And then go back double click on it and assign associativity to the spline. The only problem is that the constraint of G0 is not assigned to the spline defining points. Does anyone know of a way to assign the G0 constraint?
Are the points you are selecting point objects or something else, like line end points, center points, etc?
If they are point objects, what creates them? Are they the result of a laser scan, CMM, or something else?
If I understand correctly, you want to use a rectangle selection like in the old spline command, but create an associative spline from the points?
cowski,
You are correct in your understanding. I want to a rectangle selection like the old spline operator would allow, and then create a spline that is associative to the defining points.
Background Information:
The points are being created from Sections through curves.
I think, without better knowing, that you need to drag one at a time to a point. Then that point will be G0 to that point.
Tomas
Here's a quick journal that tries to mimic the point selection of the old spline dialog. I don't guarantee the point order will always be 100% correct - let me know if it messes up.
Code:
[COLOR=green]'NX 7.5[/color]
[COLOR=green]'April 24, 2012[/color]
[COLOR=green]'www.nxjournaling.com[/color]
[COLOR=green]'eng-tips thread561-320527[/color]
[COLOR=green]'Journal to create studio spline through existing point objects[/color]
[COLOR=green]'allows rectangle select of points, similar to old spline dialog[/color]
[COLOR=green]'resulting studio spline will be associative to the selected point objects[/color]
[COLOR=blue]Option[/color] [COLOR=blue]Strict[/color] [COLOR=blue]Off[/color]
[COLOR=blue]Imports[/color] System
[COLOR=blue]Imports[/color] NXOpen
[COLOR=blue]Imports[/color] NXOpen.UF
[COLOR=blue]Module[/color] Module1
    [COLOR=blue]Sub[/color] Main()
        [COLOR=blue]Dim[/color] theSession [COLOR=blue]As[/color] Session [COLOR=blue]=[/color] Session.GetSession()
        [COLOR=blue]Dim[/color] workPart [COLOR=blue]As[/color] Part [COLOR=blue]=[/color] theSession.Parts.Work
        [COLOR=blue]Dim[/color] displayPart [COLOR=blue]As[/color] Part [COLOR=blue]=[/color] theSession.Parts.Display
        [COLOR=blue]Dim[/color] lw [COLOR=blue]As[/color] ListingWindow [COLOR=blue]=[/color] theSession.ListingWindow
        [COLOR=blue]Dim[/color] splineThruPoints() [COLOR=blue]As[/color] NXObject
        [COLOR=blue]Dim[/color] axisToSort [COLOR=blue]As[/color] [COLOR=blue]String[/color]
        [COLOR=blue]Dim[/color] markId1 [COLOR=blue]As[/color] Session.UndoMarkId
        markId1 [COLOR=blue]=[/color] theSession.SetUndoMark(Session.MarkVisibility.Visible, "Studio Spline")
        lw.Open()
        splineThruPoints [COLOR=blue]=[/color] SelectObjects("Select objects")
        [COLOR=blue]Dim[/color] startPoint [COLOR=blue]As[/color] Point
        startPoint [COLOR=blue]=[/color] SelectPoint("Select Start Point")
        [COLOR=blue]Dim[/color] endPoint [COLOR=blue]As[/color] Point
        endPoint [COLOR=blue]=[/color] SelectPoint("Select End Point")
        axisToSort [COLOR=blue]=[/color] increasingAxis(startPoint, endPoint)
        [COLOR=blue]Dim[/color] xCoords(splineThruPoints.GetUpperBound(0)) [COLOR=blue]As[/color] [COLOR=blue]Double[/color]
        [COLOR=blue]Dim[/color] yCoords(splineThruPoints.GetUpperBound(0)) [COLOR=blue]As[/color] [COLOR=blue]Double[/color]
        [COLOR=blue]Dim[/color] zCoords(splineThruPoints.GetUpperBound(0)) [COLOR=blue]As[/color] [COLOR=blue]Double[/color]
        [COLOR=blue]Dim[/color] pointTags(splineThruPoints.GetUpperBound(0)) [COLOR=blue]As[/color] Tag
        [COLOR=blue]Dim[/color] i [COLOR=blue]As[/color] [COLOR=blue]Integer[/color] [COLOR=blue]=[/color] 0
        [COLOR=blue]For[/color] [COLOR=blue]Each[/color] obj [COLOR=blue]As[/color] Point [COLOR=blue]In[/color] splineThruPoints
            xCoords(i) [COLOR=blue]=[/color] obj.Coordinates.X
            yCoords(i) [COLOR=blue]=[/color] obj.Coordinates.Y
            zCoords(i) [COLOR=blue]=[/color] obj.Coordinates.Z
            pointTags(i) [COLOR=blue]=[/color] obj.Tag
            i [COLOR=blue]+=[/color] 1
        [COLOR=blue]Next[/color]
        [COLOR=blue]If[/color] axisToSort [COLOR=blue]=[/color] "X" [COLOR=blue]Then[/color]
            System.Array.Sort(xCoords, pointTags)
            [COLOR=blue]If[/color] startPoint.Coordinates.X <> xCoords(0) [COLOR=blue]Then[/color]
                System.Array.Reverse(xCoords)
                System.Array.Reverse(pointTags)
            End [COLOR=blue]If[/color]
        [COLOR=blue]ElseIf[/color] axisToSort [COLOR=blue]=[/color] "Y" [COLOR=blue]Then[/color]
            System.Array.Sort(yCoords, pointTags)
            [COLOR=blue]If[/color] startPoint.Coordinates.Y <> yCoords(0) [COLOR=blue]Then[/color]
                System.Array.Reverse(yCoords)
        [COLOR=blue]Else[/color]
            System.Array.Sort(zCoords, pointTags)
            [COLOR=blue]If[/color] startPoint.Coordinates.Z <> zCoords(0) [COLOR=blue]Then[/color]
                System.Array.Reverse(zCoords)
        [COLOR=blue]Dim[/color] nullFeatures_StudioSpline [COLOR=blue]As[/color] Features.StudioSpline [COLOR=blue]=[/color] [COLOR=blue]Nothing[/color]
        [COLOR=blue]Dim[/color] studioSplineBuilder1 [COLOR=blue]As[/color] Features.StudioSplineBuilder
        studioSplineBuilder1 [COLOR=blue]=[/color] workPart.Features.CreateStudioSplineBuilder(nullFeatures_StudioSpline)
        studioSplineBuilder1.Associative [COLOR=blue]=[/color] [COLOR=blue]True[/color]
        studioSplineBuilder1.InputCurveOption [COLOR=blue]=[/color] Features.StudioSplineBuilder.CurveOption.Retain
        studioSplineBuilder1.SplineMethod [COLOR=blue]=[/color] Features.StudioSplineBuilder.Method.ThroughPoints
        studioSplineBuilder1.Degree [COLOR=blue]=[/color] 3
        studioSplineBuilder1.IsPeriodic [COLOR=blue]=[/color] [COLOR=blue]False[/color]
        studioSplineBuilder1.MatchKnots [COLOR=blue]=[/color] Features.StudioSplineBuilder.MatchKnotsType.None
        [COLOR=blue]Dim[/color] knots1(-1) [COLOR=blue]As[/color] [COLOR=blue]Double[/color]
        studioSplineBuilder1.SetKnots(knots1)
        [COLOR=blue]Dim[/color] parameters1(-1) [COLOR=blue]As[/color] [COLOR=blue]Double[/color]
        studioSplineBuilder1.SetParameters(parameters1)
        [COLOR=blue]Dim[/color] nullDirection [COLOR=blue]As[/color] Direction [COLOR=blue]=[/color] [COLOR=blue]Nothing[/color]
        [COLOR=blue]Dim[/color] nullScalar [COLOR=blue]As[/color] Scalar [COLOR=blue]=[/color] [COLOR=blue]Nothing[/color]
        [COLOR=blue]Dim[/color] nullOffset [COLOR=blue]As[/color] Offset [COLOR=blue]=[/color] [COLOR=blue]Nothing[/color]
        [COLOR=blue]Dim[/color] geometricConstraintData1(splineThruPoints.GetUpperBound(0)) [COLOR=blue]As[/color] Features.GeometricConstraintData
        [COLOR=blue]For[/color] i [COLOR=blue]=[/color] 0 [COLOR=blue]To[/color] splineThruPoints.GetUpperBound(0)
            geometricConstraintData1(i) [COLOR=blue]=[/color] studioSplineBuilder1.ConstraintManager.CreateGeometricConstraintData()
            geometricConstraintData1(i).Point [COLOR=blue]=[/color] Utilities.NXObjectManager.Get(pointTags(i))
            geometricConstraintData1(i).AutomaticConstraintDirection [COLOR=blue]=[/color] Features.GeometricConstraintData.ParameterDirection.Iso
            geometricConstraintData1(i).AutomaticConstraintType [COLOR=blue]=[/color] Features.GeometricConstraintData.AutoConstraintType.None
            geometricConstraintData1(i).TangentDirection [COLOR=blue]=[/color] nullDirection
            geometricConstraintData1(i).TangentMagnitude [COLOR=blue]=[/color] nullScalar
            geometricConstraintData1(i).Curvature [COLOR=blue]=[/color] nullOffset
            geometricConstraintData1(i).CurvatureDerivative [COLOR=blue]=[/color] nullOffset
            geometricConstraintData1(i).HasSymmetricModelingConstraint [COLOR=blue]=[/color] [COLOR=blue]False[/color]
        studioSplineBuilder1.ConstraintManager.SetContents(geometricConstraintData1)
        [COLOR=blue]Dim[/color] feature1 [COLOR=blue]As[/color] Features.Feature
        feature1 [COLOR=blue]=[/color] studioSplineBuilder1.CommitFeature()
        studioSplineBuilder1.Destroy()
        lw.Close()
    End [COLOR=blue]Sub[/color]
    [COLOR=blue]Function[/color] SelectObjects(ByVal prompt [COLOR=blue]As[/color] [COLOR=blue]String[/color]) [COLOR=blue]As[/color] NXObject()
        [COLOR=blue]Dim[/color] selobj() [COLOR=blue]As[/color] NXObject [COLOR=blue]=[/color] [COLOR=blue]Nothing[/color]
        [COLOR=blue]Dim[/color] theUI [COLOR=blue]As[/color] UI [COLOR=blue]=[/color] UI.GetUI
        [COLOR=blue]Dim[/color] title [COLOR=blue]As[/color] [COLOR=blue]String[/color] [COLOR=blue]=[/color] "Selection"
        [COLOR=blue]Dim[/color] includeFeatures [COLOR=blue]As[/color] [COLOR=blue]Boolean[/color] [COLOR=blue]=[/color] [COLOR=blue]False[/color]
        [COLOR=blue]Dim[/color] keepHighlighted [COLOR=blue]As[/color] [COLOR=blue]Boolean[/color] [COLOR=blue]=[/color] [COLOR=blue]False[/color]
        [COLOR=blue]Dim[/color] selAction [COLOR=blue]As[/color] Selection.SelectionAction [COLOR=blue]=[/color] _
            Selection.SelectionAction.ClearAndEnableSpecific
        [COLOR=blue]Dim[/color] scope [COLOR=blue]As[/color] Selection.SelectionScope [COLOR=blue]=[/color] Selection.SelectionScope.WorkPart
        [COLOR=blue]Dim[/color] selectionMask_array(1) [COLOR=blue]As[/color] Selection.MaskTriple
        [COLOR=blue]With[/color] selectionMask_array(0)
            .Type [COLOR=blue]=[/color] UFConstants.UF_point_type
            .Subtype [COLOR=blue]=[/color] UFConstants.UF_point_subtype
            .SolidBodySubtype [COLOR=blue]=[/color] 0
        End [COLOR=blue]With[/color]
        [COLOR=blue]Dim[/color] resp [COLOR=blue]As[/color] Selection.Response [COLOR=blue]=[/color] theUI.SelectionManager.SelectObjects( _
            prompt, title, scope, selAction, _
            includeFeatures, keepHighlighted, selectionMask_array, selobj)
        [COLOR=blue]Return[/color] selobj
    End [COLOR=blue]Function[/color]
    [COLOR=blue]Function[/color] SelectPoint(ByVal prompt [COLOR=blue]As[/color] [COLOR=blue]String[/color]) [COLOR=blue]As[/color] Point
        [COLOR=blue]Dim[/color] selobj [COLOR=blue]As[/color] Point [COLOR=blue]=[/color] [COLOR=blue]Nothing[/color]
        [COLOR=blue]Dim[/color] cursor [COLOR=blue]As[/color] Point3d
        [COLOR=blue]Dim[/color] resp [COLOR=blue]As[/color] Selection.Response [COLOR=blue]=[/color] theUI.SelectionManager.SelectObject( _
            includeFeatures, keepHighlighted, selectionMask_array, selobj, cursor)
    [COLOR=blue]Function[/color] increasingAxis(ByVal point1 [COLOR=blue]As[/color] Point, [COLOR=blue]ByVal[/color] point2 [COLOR=blue]As[/color] Point) [COLOR=blue]As[/color] [COLOR=blue]String[/color]
 [COLOR=green]'which axis has the greatest distance between start and end points? - sort by that axis[/color]
 [COLOR=green]'possibly a bad assumption, but it's a start[/color]
        [COLOR=blue]Dim[/color] maxLength [COLOR=blue]As[/color] [COLOR=blue]Double[/color]
        [COLOR=blue]Dim[/color] maxAxis [COLOR=blue]As[/color] [COLOR=blue]String[/color]
        [COLOR=blue]Dim[/color] length [COLOR=blue]As[/color] [COLOR=blue]Double[/color]
        maxLength [COLOR=blue]=[/color] Math.Abs(point2.Coordinates.X [COLOR=blue]-[/color] point1.Coordinates.X)
        maxAxis [COLOR=blue]=[/color] "X"
        length [COLOR=blue]=[/color] Math.Abs(point2.Coordinates.Y [COLOR=blue]-[/color] point1.Coordinates.Y)
        [COLOR=blue]If[/color] length > maxLength [COLOR=blue]Then[/color]
            maxLength [COLOR=blue]=[/color] length
            maxAxis [COLOR=blue]=[/color] "Y"
        length [COLOR=blue]=[/color] Math.Abs(point2.Coordinates.Z [COLOR=blue]-[/color] point1.Coordinates.Z)
            maxAxis [COLOR=blue]=[/color] "Z"
        [COLOR=blue]Return[/color] maxAxis
    [COLOR=blue]Public[/color] [COLOR=blue]Function[/color] GetUnloadOption(ByVal dummy [COLOR=blue]As[/color] [COLOR=blue]String[/color]) [COLOR=blue]As[/color] [COLOR=blue]Integer[/color]
 [COLOR=green]'Unloads the image when the NX session terminates[/color]
        GetUnloadOption [COLOR=blue]=[/color] NXOpen.Session.LibraryUnloadOption.AtTermination
End [COLOR=blue]Module[/color]
