Make "Unpack All" for the Assembly Navigator sticky? 1
Trent5791
Anyone know if there's a way to make the "Unpack All" for the Assembly Navigator sticky?
Thank you,
Trent
NX 9.0.3.4
...and make the order default to "Alphanumeric" instead of "Chronological".
Thank you,
Trent
NX 9.0.3.4
To make the "unpack all" option sticky:
Customer defaults -> gateway -> assembly navigator -> uncheck the "pack components" option.
In NX 9, the assembly navigator order is saved with the part; once you set the sort order and save the part, it should be the same the next time you open it. I don't think there is an option in NX 9 to set the default sort order for any part you open.
www.nxjournaling.com
Thanks Cowski!
Thank you,
Trent
NX 9.0.3.4
you can also lokk at the advantage of saving and opening bookmarks isntead of .prt
The bookmarks save the blanked and unloaded status
Didier Psaltopoulos
