Make a listing of drawing 5
cad123
VN
hi
I want make a list of file to manage it . It content file name , date modified ( maybe path) and store in Ms ( Excel, Access). But it take time, do you know a software can make it automatic ?( like search in window). Can you help me
Cad123
Hi 321,
first tiny little help is "DIR2HTML".
(You will get name and size as a *.html file -> then you can copy it to Excel...
Lothar Win NT4.0 (SP6),
ACAD 2000i (SP2), ADT 3.0 (SP3),
OCÈ 5200
Or even without programs just:
use your command prompt
( start-> exec... ->%compec% <enter> )
go in the folder you have drawings
cd \(name of the folder)
and execute
dir *.dwg /ogn>>c:\list.txt
a file called c:\list.txt will be created with the list of your .dwg files sorted by name.
Of couse you can use any dir options like /s if you need subfolders too or /ogs if need to order by size.
Good luck.
Here is the best freware app I have found to solve your problems. It is called myorganizer! Just select the path to the drawings, and you can even add comments to your dwg files. Has a nice export feature to export dwg names, dates, comments etc to a tab delimited file that can be imported into excel
Try Karens directory printer . She makes a number of usefull (free) utilities. Directory printer will output to a printer or a txt file. Numerous options as to sorting, tree depth etc. Well worth trying
Ralph
Copy the following text to a file named &quot;FILE-DIR.BAT&quot;
dir > dir.txt
Now save the one line in that file.
Now copy that file to whatever directory you want to make a list of ... and double click on it ... through WINDOWS.
Give it a couple of seconds.
A text file should appear at the bottom. (dir.txt)
Import that into Excel.
See if that works for your purposes.
Let me know.
[roll1]
[spin]
[roll2]
Thanks everybody
It help me a lot
Very nice the rKeyTec idea!
I have just a small improvement, create the file with:
dir %1 %2 %3>dir.txt
so you'll can use 3 dir tags if you need. Like *.dgw /b /ong o whatever.
And throw in a &quot;|sort&quot; to pre-sort the list
Melko, I got the exact same results with your idea as I did with rKeyTek's. How is the dir.txt output supposed to be different?
Flores
Thanks guys (Melko & CADaver)! [spin]
And I figured someone would add those modifiers to the BATCH file.
And Flores ....
The difference between Melko & mine is the BATCH file.
The Drag/ drop & Double click associated to the BATCH file ... makes it &quot;windows&quot; friendly.
But really ... Melko had the right idea.
I just added the BATCH file spin.
And Melko & CADaver added the DOS modifiers which are nice! [roll2]
stars for everyone. [thumbsup]
...a star for You, rkeytek
OCÈ 5200
