zappedagain
I'm designing a piece of equipment that has two AC powered servo drives. I have a power switch that cycles the mains power (110-240 VAC), with an LED inside. The LED isn't wired directly to the switch because the switch is designed for 120VAC 60 Hz or 240VAC 50 Hz. I am attempting to avoid bringing the mains onto a PCB (for regulatory reasons) just so I can sense them and drive an LED.
Is there a simple way to monitor the mains voltage with galvanic isolation so I can illuminate my LED when the mains switch is closed?
I thought about a current monitor, but that will give a false reading if the fuse is blown.
I could add a transformer, but that seems like overkill.
No, there are no signals that I can tap from the servo drive to power my LED.
Are there any simple mains sensors available?
Thanks,
John D
Thanks,
John D
