Question for Sreid: how does a ‘metallic arc’ differ from an ‘arc’?
It is my understanding that:
[a] ‘Blowouts’ are generally used to break the arc upon contact opening.
Basically, the nature of the arc will be determined by the circuit, contacts & atmospheric conditions.
[c] When there is sufficient energy in the system (usually inductive), the energy is dissipated, in the form of an arc, across the opening contacts.
At low voltages (6-48V) and a given load (W), the relay may be designed with a contact/air gap sufficient enough to break the arc when the contacts open. When the same relay is required to switch greater loads, or when the voltages exceed 48V, ‘magnetic blowouts’ can be added to increase the effective air gap. If the magnetic field is aligned correctly, the arc will be bent outwards, and when the length of the gap is sufficient enough to break to arc, the material in the arc will be blown outwards (thus, called blowouts). Of course, if the magnetic field is the wrong way around then the arc will be blown inwards and this can destroy the relay.
The small added cost of the ‘blowout’s may double, or more, the life of the contacts/relay – load dependant.
My comments above are related to DC applications.
