Macros vs. Journal in NX8.5
OldCADPOPro
Aerospace
Aug 15, 2014
37
Hello All,
I was searching for an existing forum on this topic, with little success. Therefore I would ask this question.
I am creating a series of macros to simpify things like changing the format size of a drawing (including the imported border), adding part attributes to models and drawings etc... My question is really more along the lines of using a Journal over a Macro. Can anyone shed some light on which one is better or more editable?
Thanks in advance for any advice.
Richard Andrew
Aerojet Rocketdyne
Macros are usually version dependent as they are capturing keystrokes/menu picks.
Journals will allow more flexibility, easier to edit and should work with future versions.
VBA or UGopen C/C++ code can also do what you need, but may be more complex in their programming requirements.
Ben Loosli
Journals allow you do to things like looping and branching fairly easily. Where you might create a macro for each template size you use; a journal could be made to query the drawing sheet size and import the correct template size automatically for each sheet.
www.nxjournaling.com
Thanks all for the feedback. I have been evperiencing some issues with macros so I created a journal to test adding attributes to models and drawings. Now I want to add them to a User Tool. What is the callout for a journal file for the TYPE to run a journal file? The NX documentation only has MENU_BUTTON, MACRO, GRIP, UFUN, or USRT. Strange thing is i can call a journal file with a customized toolbar in NX. Any Help is appreciated.
Thanks,
Richard Andrew
This is how I call out journal files.
Toolbar File (.tbr)
BUTTON <B1>
LABEL <Label>
ACTION <Path to journal file>
Menuscript File (.men)
BUTTON <B1>
LABEL <Label>​
MESSAGE <Description of button>​
ACTIONS <Path to journal file>​
Just replace what's in the <> with whatever you need and do not include the <> in your file.
Daniel Sikes
Design Engineer
Young Touchstone
NX 8.0.3.4
Hello Daniel,
Thanks for pointing me in the right direction. I am thinking of converting my old user tools to updated menus. Attached is a picture of my current setup. I am assuming I need to create a new .men file that then points to several toolbar options. Any advise on structure is appreciated from anyone.
Thanks,
Richard
 http://files.engineering.com/getfile.aspx?folder=649ea475-ee29-4aef-a69b-5e66a5ce21cd&file=drafting_UT.PNG
See attached for an example of how to have nested menus using the menuscript. This is from the NXCustom set of files that I downloaded from the Siemens community forums here. This may not be exactly what you are looking for but hopefully it's useful. I think there is a way to add icons to them as well but I don't know the format for that offhand. I would definitely recommend having a look at the NXCustom setup for your version of NX and see if there is anything that might help/be useful for you.
Daniel Sikes
Design Engineer
Young Touchstone
NX 8.0.3.4
 http://files.engineering.com/getfile.aspx?folder=e3829d3d-ad26-41d4-abf3-0b4c43805302&file=menu_example.zip
Hello All,
Thanks to everyone who provided input to the thread. I have modified our user tools and am migrating away from .UTD files to Toolbars and Menus. Attached is a shout of what I did for us here. Thanks Again for your direction.
Richard
 http://files.engineering.com/getfile.aspx?folder=0852203e-1444-4645-b667-04279dffad5f&file=new_User_tools.png
