Macro - Tree Display 1
SBaugh
I tried to record a macro, then followed the process that I want the macro to do which is to change the tree display.
Turn on "Show Component Description"
Turn off "Show Component Confugration Names"
Turn off "Show Display State Names"
I need it to run for any assembly.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Dim COSMOSWORKSObj As Object
Dim CWAddinCallBackObj As Object
Set CWAddinCallBackObj = swApp.GetAddInObject("CosmosWorks.CosmosWorks")
Set COSMOSWORKSObj = CWAddinCallBackObj.COSMOSWORKS
boolstatus = Part.Extension.SelectByID2("", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
Part.ClearSelection2 True
StudyManagerObj = Nothing
ActiveDocObj = Nothing
Set CWAddinCallBackObj = Nothing
Set COSMOSWORKSObj = Nothing
End Sub
If fails on the
Then nothing happens... I have no clue about how macros are supposed to work if it doesn't record what I actually did and what I want it to repeat.
Any help would be appreciated
Scott Baugh, CSWP [pc2]
CAD Systems Manager
Dapco, INC
"If it's not broke, Don't fix it!"
faq731-376
That was my poor typing skills I think you are talking about. Here is the Code:
Dim swApp As Object
Dim Part As Object
Sub main()
End Sub
CAD Systems Manager
Dapco, INC
faq731-376
Try the following codes (have not tested but should work for model files)
Option Explicit
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swFeatMgr As SldWorks.FeatureManager
Sub main()
Set swModel= swApp.ActiveDoc
Set swFeatMgr = swModel.FeatureManager
swFeatMgr.ShowComponentDescriptions = True
swFeatMgr.ShowComponentConfigurationNames = False
swFeatMgr.ShowDisplayStateNames = False
End Sub
Deepak Gupta
SOLIDWORKS Champion and Expert
SW 2022 SP0.0, 2021 SP5.1 and 2020 SP5.0
Boxer's SOLIDWORKS Blog
