macro in a lisp can it be possible??
shadow
Computer
Now that i have a need to use lisp more im trying to put the little i know to use but one of the easys at least for me to do is write macros so in knowing that can i use the (command "_.Autocad Command" )in conjunction with macro info like so
(command "_.offset" "\" "\" ";")
would this work in lsp or in some weird way can it if anyone knows anything let me know if everyone helps everybody the world will be a better place
yes dear by using this way macro can be possible in lisp also
but back slashes don't work or atleast they aren't for me does anyone know of the syntax that you use for button macro style syntax for lisp if everyone helps everybody the world will be a better place
