Hi there,
I am designing a "square" made with wide flange beams. It is made with HEB160 beams and the outer dimensions are roughly 700x800 mm2.The plan is welding it.
I am concerned about the accuracy of the whole system, what tolerances we have in the overall dimensions after welding. What is the typical precision one has in this kind of structures?
We plan to make a double V butt welding
One problem we face is the bead interferes with the parts which go bolted up and down this structure. So I was thinking about putting the welded assembly in a milling machine and getting rid off the upper and lower beads. Is this recommended? Just from one side of the V-butt-welding, maybe doing this is crazy...
thanks
![URL]](https://res.cloudinary.com/engtips/image/fetch/w_800,c_lfill,q_auto,f_auto,g_faces:center/[URL unfurl="true"]http://i.imgur.com/O628wXd.jpg[/URL])
![URL]](https://res.cloudinary.com/engtips/image/fetch/w_800,c_lfill,q_auto,f_auto,g_faces:center/[URL unfurl="true"]http://i.imgur.com/ZEsBpQR.jpg[/URL])
![URL]](https://res.cloudinary.com/engtips/image/fetch/w_800,c_lfill,q_auto,f_auto,g_faces:center/[URL unfurl="true"]http://i.imgur.com/sZglox9.jpg[/URL])
thanks
