Machining advice 1
LuckyJim
Nuclear
GB
Hello, I am new to this forum. Does anyone know of a good online resource for machine tool advice. I am designing a component to be machined from aluminium but it will require some delicate features at considerable depth (up to 10 x diameter of cutter). I would like to find out what's reasonably achievable before I progress too far....
Any ideas?
hi Again
I should of added, if you have manufacturing centre on site I would make a sketch and go and talk to someone either a machinist or a manufacturing engineer, failing that phone up a local machining company they are usually quite willing to help.
desertfox
You might also try forum281. There's a lot of machining people there.
-handleman, CSWP (The new, easy test)
LuckyJim,
Talk to the people who will be fabricating it.
Here is a good article by Joe Osborne: Tips on Designing Cost Effective Machined Parts.
JHG
hi LuckyJim
Anyone posting information should see this post too:-
thread281-267076
thread1103-197339 had a link to a pretty good site.
However, for your 10X depth, I'd want to speak to an actual machine shop.
Machining is for machinist not the designer. Ask a machinist if it can be done like you wish, work with him.
Delicate features at considerable depth?
I imagine you are choosing aluminum over steel because of it's machinability. However, if you are willing to go to a steel and if this is a one-off or few-off, DMLS might be the way to go.
The costs seem to run about 2x-3x that of an SLA, but for something with alot of fine detail, it might be cheaper than machining.
Chris Loughnane - Product Design
