Thank you all for your your responses and guidance. It is greatly appreciated.
Jayrod, I understand about flexibility with lumber, although I was hoping that if I used something along the lines of 2x10 or even 2x12 that it would be rigid enough to allow for some spread loading. I had also considered using structural steel, but other than finding published span ratings similar to what I'm asking for here with lumber, I've not looked much further into it. If I'm at an impasse with lumber, I will do just that. I could also join a structural steel member to the side of the 2x for additional rigidity.
I had mentioned that I could sister a new truss up against the 1st truss to double the capacity. I had a thought that I could also put structural sheathing on the backside of the 1st truss to add rigidity, as well as taking such a great load off of the metal truss connections.
gte, I will approach the truss makers. I'm trying to get a good idea of what my options are before doing that. My limited experience so far with truss makers is that they are not very willing to stray from the focus on what the trusses are designed specifically for, and that since this landing was not considered initially, that I'd still be on my own to come up with a solution. I hope that I will be proven wrong in this case.
My needs are fairly modest. I'm looking at roughly a landing only big enough for a person to enter and exit a set of 2-1/2' wide alternating-tread stairs that approach parallel to the loft face. The stairs make a 90 degree turn half-way up, so there is no chance of any large, heavy objects such as furniture getting up to that landing.
Thanks again, Tim
