Luer-Lock dimensions and drawing 1
IL
Hello everybody.
I'm trying to find the "Male" of S.S. Luer-Lock tube connector (quick turn tube fitting) , I am designing some medical instrument and I need the standard dims. of Luer-Lock.
(if you search for Luer-Lock) in mcmaster ( you'll see which connector I'm looking for.
Michael
You can buy the ISO standard for less than US$60.
ISO 594-2:1998
"Conical Fittings with a 6% (Luer) Taper for Syringes, Needles, and Certain other Medical Equipment"
Part 2: Lock Fittings
Price$58.00
Luer taper is 6 degree if I remember right. You can do a web search and get some of the other dimensions from suppliers. Also, if I remember right there may be some subtle difference between plastic and metal luers.
Jim
Were you able to get the dimension and drawings of luer-lock, I'm in the process of making a test fixture that requires the specs of the luer lock dimensions
alvramon
