Hi all,
I have a simply supported 3 meter I beam (180mm deep) which supports grating panels on both sides. The beam is overutilized in bending to around 130% if it is considered susceptible to LTB. The grating panels are clamped as shown in the picture per 800mm. You can also see in the picture the direction of load bearing bars of the grating. The load comes from the gratings (i.e. no grating no load). Would you consider the detail shown to restrain the top flange, or would you increase the size of the beam (implying extra weight, extra work, etc.)?
