LSR Molding & Assisted Gas Injection 1
  • Thread starter Thread starter GT
  • Start date Start date
GT
IE
I am working for a medical device company who is searching for a method / information to inject mould LSR. The part shape is similar to a ‘toy balloon’ in that the material is flexible. The wall thickness is thin, less than 0.5 to 1mm and the overall product dimensions is about the size of a clenched fist. The final product which we wish to achieve is similar to a protective cover for a ‘light bulb’. <br>
<br>
My research to date suggests that ‘dipping’ is the main method used for manufacturing balloons, condoms and so on. Dip molding is not acceptable and our goal is to develop a solution using Liquid Injection Molding or a process closely similar. We’re also considering the possibility of using an ‘Assisted Gas Injection’ process.<br>
<br>
Any advice or pointers you can direct me towards would be very much appreciated.<br>
You may want to consider blow molding, if production volume is high (50,000+ units).&nbsp;&nbsp;Another alternative is rotational molding.&nbsp;&nbsp;Check your local yellow pages for a manufacturer.&nbsp;&nbsp;They should also be able to help you with finding a mold maker.
