I was asked about some LSL wall studs that are bowing and I can't figure out the cause so I wanted to see if anyone else could provide some insight.
House is 42'x32'. Roof trusses (vaulted) span across the 32' dimension with gable ends. Bearing walls on each side are 15' tall. End walls (non load bearing) are 18' tall studs maximum. There is a full length porch along one 42' side. There is an open second floor (loft) opposite the entry/porch (17'x42'). The entry faces west.
The north non-load bearing wall has a 1" bow in it (strong axis). At the northwest corner the wall is straight. At the ~midpoint of the north wall it is straight as this is the start of the second floor (loft). Between the corner and the second floor the wall stud bow gets worse. About 8' from the corner is the maximum wall bow (~1" from a string line pulled top plate to sill). The top plate and the bottom plate are both straight. Wall framing is 2x6 lsl studs @ 16" o.c.
The west load bearing wall is straight. The south non-load bearing wall is straight. The east load bearing wall is straight.
Any thoughts on the cause?
Thanks.
JH
Thanks.
JH
