Dear Sirs
i'm fresh mechanical engineer and i'm in trouble with an LPG pump..
i have to evaluate a tender of this pump, and i'd like to have some advice about:
1. is there a book of reference for assensing pump in accordance with API 610?
2.
LPG properties:
T= 83 °C
relative density= 0,557 kg/cm^3
viscosity= 0,137 cp
vapor pressure = 14,57 bar abs
head= 400 ft
flowrate= 166 m^3/h
pump suction = 7 bar g
pump discharge = 13,87 bar g
lenght from 1 stage impeller to discharge = 3 m
Operating point of this pump is near of end curve and very distant for Best efficiency point...and is not in accordance with api 610 referring to preferred region and allowable region..
My question are the following:
1. i have extimated the pressure at eye of impeller (8,7 bar g)...how can i evaluate if lpg flashes??
2. in this situation i think pump is to reject, because its operating point is not affidable and subdimentionate, and then could causes problems to electric motor..in your opinion is my mind correct?
What additional controls would you do?
Best regards
ps. operating point is represented in attached file.
2.
LPG properties:
T= 83 °C
viscosity= 0,137 cp
head= 400 ft
flowrate= 166 m^3/h
Best regards
