I have a question about PWHT:
Vessel base material is SA-516 Gr.70N, vessel will be exposed to alkanolamine and wet H2S.
Our vendor informed us that PWHT was performed slightly below 620°C. However, results of hardness test were below the maximum value of hardness required in H2S specification - 200 HB. Testing was provided on the base material, HAZ and weld material.
PWHT procedure shall meet NACE SP-0472 specification (3.4), which says:
“when PWHT is being performed for prevention of ASCC (Alkaline Stress Corrosion Cracking), lower temperatures (lower that required 635±15) shall not be used.
It means that we cannot accept PWHT performed below 620°C.
On the other hand, repeating of PWHT can negatively affect impact toughness of base material.
What do you think will be better to apply in this situation?
