Lower Heating Value of a non-ideal liquid mixture
sheiko
Chemical
May 7, 2007
422
I'm looking for a correlation or a formula to calculate the Lower Heating Value (LHV) of a liquid mixture. Any idea?
"We don't believe things because they are true, things are true because we believe them."
The liquid is Fuel Oil.
You can use values for each individual component and sum then on either a volume, mass or molar basis (depending on your table values).
Best regards
Morten
A general formula for a pure hydrocarbon would be:
LHV = 8080 c + 28600 h......kcal/kg
where c and h are mass fractions of carbon and hydrogen, respectively.
A fuel of venezuelan origin (Oficina) some 60 years ago had the following values:
oAPI Mol. weight c h s LHV
10.9 ~380 0.855 0.116 0.018 9665
9.6 ~390 0.858 0.114 0.018 9630
8.0 ~415 0.861 0.110 0.019 9590
s is for sulfur.
These LHV may serve you as indicative values.
