On my 1st Gen Tundra, lower BJ failures are common. So common that it is standard practice to replace them with OEM every 100k miles. Toyota had a recall and improved the joints but the failures persist.
Seems the issue is the suspension is designed so the joint is in tension. Spring/shock attached to LCA, stud pointing downwards.
Is it common to design suspension like that? It would seem having the joint in compression would be safer.
