Low Voltage cable secured w/in 12" of Device
eatapeach
Military
Jun 20, 2013
78
Are the requirements to secure low voltage cable the same as for power cables (within 12" of a device)? The Caddy supports are 5'oc however it seems to need something closer to the Wattstopper box to secure it from someone lifting a ceiling tile and maybe disconnecting it. Any code section per NEC would be helpful. See attachment for the box located on the side wall with green cable.
 https://files.engineering.com/getfile.aspx?folder=a148c9a1-7185-44d3-af24-cfa9e1e6c06b&file=3-14-2019_025.JPG
Not the answer that will help you, but given the similarities between the NEC and the CEC, this thread may be of interest:
thread248-451201
Bill
"Why not the best?"
Jimmy Carter
