dcStrucEng
I am working on a project in which a large portion of the first floor area will have a floor finish consisting of an exposed polished concrete slab on grade (6" thick). The goal is to maximize the control joint spacing as much as possible while still providing for the typical isolation joints around the columns. It seems that the best approach would be to use low shrinkage concrete or shrinkage compensating concrete to achieve this goal. However, I haven't found much literature on how to determine joint spacing using low shrinkage concrete.
I reviewed ACI 223, but unless I missed something, I didn't find any guidance in there. The columns are spaced at approximately 25 to 30 feet on center. The architect realizes that there needs to be control joints, they just don't want them to be 12 foot on center each way. They are hoping for spacing more like 30 feet.
Any advice would be appreciated.
