riveter1
- Jul 31, 2005
- 7
I have built a low pressure fluid system for an R&D application. It is made with 1/4" pvc tubing and push connect fittings. It operates at about 10 mm Hg (about 0.20 psi) and uses a paristaltic pump rated at 24 ml/min. I have installed a reservoir on the pump inlet for filling the system, a low point drain, and a high point vent. I have also installed a pump discharge needle valve and a pump bypass line with a needle valve. Now I would like to install a pump inlet check valve, but I can't find one with a low enough 'cracking pressure'. I need it to open at less than 0.20 psi. Most of what I have found has a cracking pressure of 1 psi. Can anyone give me any leads on a check valve for this application? Schematic attached.
Mark
Mark
