The tensile results will be influenced primarily by carbon content not molybdenum. Molybdenum, influences hardenability, as mentioned by CoryPad, and elevated temperature strength. I would re-check the chemical composition results, and if it is not 4140 either send it back or use as is knowing it is not 4140. You mentioned B7 in your OP, is this supposed to be A 193 Grade B7 material?
