Skogsgurra
Hello world!
I am trying to get a good picture of the worst transients one can expect on normal low voltage grids in different parts of the world.
Personally, I have met one transient that tripped drives and other equipment in a whole region. It was caused by 39 Mvar phase compensation capacitors being switched (unsynchronized) to a 130 kV transmission line and generated a dip-plus-peak-ringing that made the 500 V grid peak at 940 V. See attached recording. The upper trace shows VFD DC link voltage being pumped up by the transient so inverter trips.
That is the worst I have seen in about 40 years, this was in 1991. I guess that I have been lucky - there must be much worse transients. I am not asking about lightning hits or indirect hits, they are usually in the microseconds range, but transients with lots of energy. The width of such transients is usually one or two milliseconds - perhaps more.
It would also be interesting how you handle such potential threats. What protection is used?
Gunnar Englund
100 % recycled posting: Electrons, ideas, finger-tips have been used over and over again...
Gunnar Englund
