I know that allowables in B31.3 are based on a maximum cycle life of 7000 and you apply the reduction factor for designs in excess of this.
I also know that the code doesn't allow you to take credit for a higher allowable for less than 7000 cycles. But, from a practical standpoint, is there much that can be gained in terms of a design stress by considering a lower cycle life?
I'm faced with a unique problem in that adding enough flexibility to accomodate the stresses based on 7000 cycles is creating pressure drop issues with the amount of tubing required to handle the displacement. The client is asking if a design life of 500 cycles, that they could guarantee, would help in reducing the length required. They are aware that this is going to be stepping outside the code.
So, I'm looking for a couple of things. First - is there any point to pursuing this?
And, if so, can someone share some references that I can look into to tackle this issue.
Thanks,
Edward L. Klein
Pipe Stress Engineer
Houston, Texas
All opinions expressed here are my own and not my company's.
Thanks,
Edward L. Klein
Houston, Texas
