lost command line
dbabb
Automotive
I have lost the command line from my autocad r14
screen. How do I get it back? thanks.
Please try options where number of lines to be visible on commandline is set.
Either, as far as I know R14 the number of lines in Command window MUST AND CAN BE 1 to 100, try this:
Go to Tools menu > Preferences
Open Display tab and in section Text window parameters set the "Number of line of text to show in docked command line window" to desired number of lines 1-3 (2 is quite OK of you are experienced)
Otherwise, reinstall will help anyway!
Good luck&regards
