In a meeting to discuss discard criteria of Steel Wire Ropes a Rope Manufacturer suggested that the frictional heating effects of ropes formed from multiwire overlays subject to cyclical bending would lead to a reduction in service life due to other than fatigue.
Whilst aware that the wire rope can reach temperatures of 100+ 'C I was under the belief that this exceeded the pour point of the Grease, lubrication was lost and there follwed an increased wear mechanism which was the route cause.
But I was told this was not simply the case and if it were potentially an issue other lubricants could be used with substantially increased pour points. Instead I was told it was a metallurgical effect of the metal.
The rope are made for wires of typically a non-alloy carbon steel with a carbon content of 0.4 to 0.95% tensile strength 1760 to 2360 N/mm2. They may have been through a compacting process which involves crawing the wires through a shaped die.
Can anybody please suggest what mechanism could lead to loss of properties in the 80 to 100'C range. A subjective assessment on the effects of this mechanism.
