Looking for Wire Routing Options in 2008
nornrich
194
All,
I just recently did an assembly where I need to draw in the wire routing. This is the first time I've looked for this functionality in SW2008. I know that in earlier versions there was an add-in that came with SW Premium, that provided wire routing. Can someone give me some guidance
Rich.....[viking2]
Richard Nornhold, PE
There is a routing add-in for 08. I have it and have used it, it is very thorough but if you havent used it before it's going to take you a while to learn it.
If you simply dont have the time and resources to go the add-in way, you're going to have to create the routing using sweeps. The level of detail which you create these sweeps is up to you.
SW2008 Office Pro SP4.0
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
