Looking for RAGEE in post
donovanb2
The post was removed and I can't get in touch with RAGEE, one of eng-tips member. He had a question about ABB robots.
Donovan
donovan@highstream.net
See:
Industrial/Manufacturing Engineers Area - Automation & Robotic engineering Forum
RAGEE (Electrical) 04/12/03 (posted 04/12/03) 0 replies
ABB UNIX operating system experiance?
<nbucska@pcperipherals.com>
It is back -- two posts lower
It is gone again -- someone is playing &*(&#^@@*@@ games.
Here is his posting (without the name R.A.G.E.E )
Hi All,
This is a curly question about what ABB refers to as &quot;indian Territory&quot; (in jest). I have been recently experiancing problems with an IRB 4400 S4C+ controller where the flash disk has been inadvertantly filled to capacity & the robot no longer wants to play. What we are left with is the controller continuosly running through its boot cycle, so to remedy this problem I have connected to the unix operating system through Hyperterminal & deleted some of the larger unnessecary files. This has enabled the controller to continue through its boot cycle enough to cold start the controller. After repeating the process twice to remove two of the loaded systems it will not reboot a third time to remove the last operating system. I am interested in hearing from anyone that has had a aimilar experiance & may have a fix for the problem. I also intend to update the thread with the solution when I find it.
Russell Gee
