I am looking for Ra and Xa values for 3/8" High Strength Steel (HSS) wire. Normally I have found Ra values for conductors @ 25, 50, and 75 degrees. I have looked for these values for 3/8" HSS with little success. I have a couple of venders looking into this for me, but I have not heard back yet. So I will try here next.
The ONLY source of Ra and Xa values I have in the "Southwire Overhead Conductor Manual". Table 1-39 has impedance data for various grades and diameters of steel conductor. However, instead of Ra and Xa @ different degrees, the table list Ra and Xa @ 10, 40, 70, and 100 amps. So I am not sure which value, if any, to use.
I need these values for impedance calculations for various transmission (69-138 kV) structures. If anyone has any info one this, I would be very thankful. I need to know Ra @ 25, 50, 75 degrees and Xa for 3/8" HSS. Or at least maybe which values in Table 1-39 to use.
In the Table 1-39 there is a 20 degree DC value for Ra but I do not know where to find the conductivity constant (228.1=aluminum, 241.5=HD Copper)of HSS Grade A wire is.
Howard
Howard
