Trying to design a pneumatic system. System is a length of pipe/tubing with several holes in the tube. Knowns are ID of tube, source pressure, hole diameter, spacing of holes, length of tube, source cfm rate and all knowns are mostly adjustable. Would like a formula to determine the pressure and cfm rate at each hole with the knowns. Example, a .50 inch ID tube, 22 feet long, 5 holes @ .063 diameter spaced 5 feet apart with 1 foot at the ends, end of tube is capped, source pressure 200 psi and 10 cfm. System is at atmospheric normally, until valve opens and releases source pressure and cfm into tube creating 5 air jets from tube.
Thanks,
mcs
Thanks,
mcs
