Guest
Here's a wierd question/problem. I have several pieces of DIN rail mount equipment in my system.
There is an absolutely great DIN rail mount on a Compumotor controller that I have. It is an aluminum extrusion with a spring wire clip. The mount holds it so it will not slide along the DIN rail, which is very nice for my particular application.
I have seen the same mount on a power supply from Phoenix. I would like to mount some other equipment with these mounts, but I have not found them anywhere.
Can anybody suggest a source for some of these good DIN Rail mounts ????
