Looking for a Quicker Way from Solid to Frame
alj722
Aerospace
Nov 4, 2004
39
I'm trying to find a quick and dirty method to go from a general solid with planar sides to a frame. I have a large number of solids and would like to create frames for each quickly (this is just for a conceptual design, so I don't need a lot of exactness). I remember doing some tricks with Shells many years ago (I think in IDEAS) to pull this off with just a few clicks but haven't found anything better than the attached version. Anyone know a quick way to go from a solid (such as a box shape) to a frame like the attached? I'd be happy with box beams instead of L beams.
Thanks,
Drew
Hi.
If you have a license for routing you could "mis"-use that..Just create a stock with the profile you want and apply that to a path which has the shape you want.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
