looking for a material
nikaul
I am looking for a material which when takes load behaves as graph attached. I would be really grateful if anyone can suggest the material.
How about a loose chain? Displacement continues until the slack is removed, then moves according to its modulus of elasticity.
BA
Of course, it is not so good on the compression side.
BA
I think it is safe to say that no such material exists.
BA
The first thing that came to my mind was a loose cable (similar to BAretired's chain), but then I thought "that's a system, not a material". I agree with BAretired. I've never heard of a material that can deflect without taking load and then all of a sudden become stiff when the load hits a certain point.
not sure what your application is, but looks like you need a slotted connection...or some kind of yet to be discovered material as mentioned above.
How about a sponge? It wouldn't offer 0 resistance, but in tension it would be very soft until the fibres were stretched out. In compression it would behave similarly until it was fully consolidated.
A slotted connection is the only thing I can think of that will provide the tension and compression components...
Dik
Thank you all for those suggestions.
Iron at the yield point.
Michael.
Timing has a lot to do with the outcome of a rain dance.
