DoctorColdSaw
New member
Hi All,
I'm making a self levelling mechanism using a weighted cage in a bearing. As the cage approaches horizontal the turning force to overcome any stick or friction in the bearing approaches zero. With an insufficiently free running bearing the cage does not self level. It gets stuck at 10 - 15 degrees off.
A complication is that the mechanism has to damp excessive rotation ie it can't be so free running that once set in motion it'll just swing back and forth ad nauseum.
My idea is to find a bearing which uses a non-newtonian fluid as it's bearing medium i.e. it has an inner & outer shell but no balls or rollers. The fluid carries the load.
I do know that such bearings exist but I cannot find anyone that sells or makes them. Searches for "fluid filled bearing" return hits for standard hydrodynamic bearings. Whether I can get a fluid filled bearing filled with a non-newtonian fluid remains to be seen.
Thanks for any pointers.
Wilson.
Wilson.
