handleman
Automotive
- Jan 7, 2005
- 3,411
OK, I know this is a really long shot, but has anyone figured out how to use the swDocumentMgr.dll calls? I believe they have to do with Solidworks Explorer. They're unsupported, but I found this link showing it being used somehow. I can't read whatever the language is. Not the programming language, but the other language. It seems to require some sort of license key string - "7B6BC9E" on that website, but I'm guessing it's generated when you install SW or something like that.
The reason I'd like to use it is that I want to read the Update Stamp from the stored version of an open file and compare that value to the current value of an open SW document. To do it with SW I would have to create a copy of the file and then open the copy. Obviously that's a poor way to do it.
Anyway, as I said I think it's a long shot here, but I thought I'd give it a try before I play "Stump the VAR".
Thanks!
Thanks!
