In processing a moving forward hot metal bar (roughly heated at 2000F), I need to identify whether that bar is moving or not. We are currently having a sprocket rolling on the bar, reading the teeth with a solid-state proxy switch. Heat build-up becomes quickly an issue, both for the sensor and mechanicaly.
I am aware that non-contact motion sensors are available, but the detection range is so short (1.5" at most) that I would burn it almost instantly.
I either need a zero speed detector or simply a input, when the bar is moving, that I would treat with my PLC.
Would anyone know of any technology that could enable me to detect that the bar is moving without being to close to it - 24" is safe from radient heat.
Thank you,
Thank you,
