waytsh
- Jun 10, 2004
- 382
Hi All,
I have designed a reinforcing solution for a barn timber using bolted steel side plates. The contractor is having trouble sourcing the long A325 bolts required. I can't really use lags bolts, at least on the backside of the timber because of clearance with the roof. Is there a good alterative that might be a little more readily available? Could I use cut down threaded rod or maybe F1554 Grade 55 anchor bolts? I figure you clever folk will have some ideas.
Thanks!
Thanks!
